Hunter 376 Dining Table Finish
DSqr
Feb 27, 2010
48
Hunter 376 Racine, WI
We had water intrusion coming down the mast last winter and it got into the coating on the table and ruined the veneer. I've sourced new teak veneer, but I don't know whether the finish was varnish, epoxy, or some other finish. Any thoughts/recommendations?
BW1973
May 11, 2019
10
Hunter 340 OGYB
I have the same issue on my 2001 H 340. Where did you get your veneer and what part/model number? One of my spring 2025 projects.
Jun 1, 2009
1,860
Hunter 49 toronto
Dug a little bit in my Hunter files archive.... found this one (attached)....
I would use a 2 part epoxy for a beautiful high build finish. Either that, or 8 coats of gloss varnish. The results are worth the effort
