Microwave
Mar 30, 2025
9
hunter 49 Mount Sinia
I have a 2008 hunter 49 ,and my microwave is not working properly. When doors is closed it still running.
anyone have same problem. Also has anyone removed and replaced same ,how to remove.
thanks in advance for any help!
MFD
Jun 23, 2016
249
Hunter 41DS Pacific NW USA
I have a 41DS, wouldn't be surprised if it's the same microwave or a substantially similar installation - can you post a picture?
I have replaced mine a couple of times.
Never had one keep running on its own though.
Mar 30, 2025
9
Will get a picture But it’s the one with coffee pot on side
colemj
Jul 13, 2004
835
Does it turn itself on when you close the door, or does it just resume previous operation? Is this a new behavior for it? If ours is hot inside, it runs a fan by itself that makes it sound like it is on, but it is only the fan and not the magnetron running.
Mark
Mar 30, 2025
9
Mark
It resumes .this just started at the end of last season.
Jun 21, 2004
3,055
Beneteau 343 Slidell, LA
Could be one or all three of the door switches. Can get a set of new switches for under $10 From Amazon. Make sure that you buy switches with correct configuration. (On / off). Could also be the circuit board.
9
Thanks for info will try that
Jun 21, 2004
3,055
Be aware of the switch configuration. some are configured to work in a normally open configuration; some are configured to operate in a normally closed configuration. Should be marked on the switch housing. Pay attention to where each type of switch is located on the door closure mechanism.
Mar 30, 2025
9
Will do thanks
Jun 1, 2009
1,863
Hunter 49 toronto
I know this unit well.
It was discontinued ages ago,
I’d like to buy your coffee pot, assuming it’s in good shape
Please PM me on this
