Do diesel engines that are used as dedicated land based generators run at very high rpm's? What is the difference in use case between two identical diesel engines, one used as a generator and one used as an auxiliary engine?
I'm curious. I hear people say all the time that running a diesel engine at lower rpm's on a sailboat with no load is bad for the engine, but dont diesel generators do this all the time? Why is it bad for a sailboat engine and not bad for the generator? Is it the fact they run for very long lengths of time in one go, or is the electrical producing coil enough of a load to act like an engine in gear? Do they run at very high rpm's? I have heard diesel generators running before and they dont appear to run at 2700+ hundred rpm's, but i may be incorrect on this.
I hear of diesel engines as generators that last decades so it cant be all that bad.
