This is a continuation of my post Antifreeze Leak. I still have the antifreeze leak. It appears where I was finding the drip from the motor mount bracket was diesel. The top of the injection pump is wet with diesel, I thought it was antifreeze. The issue with this leak is that it doesn't occur when the engine is running or 8-10 hours later. after I have run the engine in the afternoon and check it the next morning I find the leak. It is not where the injection pump is mounted on the engine, but on top of the injection pump. I have looked at the parts breakdown and trying to determine what could be producing the leak. Hopefully someone with this same engine M25XPB has had this problem. I finally hired a mechanic who took the hose off the banjo fitting cut a small amount of the hose off loosened then tightened the banjo fitting and reattached the hose. Ran the engine no leak checked again at 11:30 that night no leak. In the morning next day diesel on top of the pump again. My theory is when the engine is hot metal expands as it cools metal contracts and then I see leaks. Have called the mechanic back and will see what he says. Any suggestions would be greatly appreciated, have been working on this for 3 weeks.
Thanks,
Mark
Thanks,
Mark
