So I think I have a problem. I just bought the meter and according to the limited info on the web, It should work right out of the box.
The results below are from my test at 25 watts. From everything I have been able to learn so far, I should have a reading of somewhere in the range of 1:1.5 or for this meter, I believe i should see a reading of ideally 1.5 or lower on the display. My reading is clearly nowhere in the ballpark. I'm not seeing anything in the manual or online that suggests I have a setting thats wrong or has been altered on the meter.
Clearly my transmission power is not getting out as well and it seems a lot is bouncing back. I'm guessing it would just be a connector issue? The Antenna is a standard marine VHF antennna so i cant imagine would be an issue.
I ordered good quality crimp on connectors and a proper crimp tool. Three of the four connectors are inside the boat an easily accessible. I'm guessing I should start there. Hopefully its not the mast top connector
Thanks for the previous advice in other thread to check with SWR meter. I'm glad I did...
This is the VHF I have.
