SSB ground Plane Option
Sep 27, 2008
251
Hunter 41 Longport,NJ
Tried all the diagnostics - my shroud-mounted antenna is not doing the job. Has anyone used this ?
dLj
Mar 23, 2017
5,256
I don't have direct experience, but I've heard good things about this.
dj
7,747
Alden 50 Sarasota, Florida
It works but it’s probably the most expensive way of creating an effective counterpoise. To be clear, this isn’t an antenna; it’s a counterpoise for an antenna.
In A/B testing, a good connection to any nearby bronze thruhull can actually be more effective in certain circumstance.
What counterpoise are you currently using?
251
Connected to thru-hull, but I need to check the integrity of the line this spring
