Over the past couple of years our waste tank sending unit, and fresh water to a lesser degree, have gradually become less reliable, to the point where our waste tank now shows permanently between 30% - 50% full (e.g. it is currently empty and still showing 30%). Then, after the most recent diesel fill, that sending unit now shows (and alarms) that the diesel tank is always empty. So I thought it time to investigate and fix them all.
After consulting the manual and the Hunter Owners Store, I was expecting to find a top mounted sending unit with serial code on each of the three tanks. What I found is a top mounted diesel sending unit with no serial code, and two external sensors on the side of the waste and fresh water tanks (photos attached). Our boat is a 2004 model, so perhaps they changed the sending units towards the end of the run.
Before I contact the online store directly, I thought I'd check in here and see if the brains trust can shed any light or similar experiences with these sending units. Not sure if they are a "must replace" or can be cleaned or otherwise repaired.
Thanks for any advice and guidance.
Edit: since posting I've just discovered the water/waste tank units listed as "Water Sensor Moda" on the Hunter Store. So only the diesel tank unit is now a mystery.
Robert
Hunter 306 "Charisma"
Westernport Marina, Melbourne, Victoria, Australia
Robert
