Teak Handrail Bedding
Oct 27, 2024
21
Hunter 27-2 Rogersville
I am in the process of replacing the badly weathered teak handrails on my 1989 Hunter 27. When the time comes to install them, do I "bed" them with sealant at the contact points with the cabin top, or is there something more specific I should be using?
Mar 27, 2024
56
Hunter 39 Wickford
You should bed them. For no other reason than you want to make sure the fastening holes are sealed. I've used life caulk in teak color for this in the past. I'm sure there are multiple different products that will work.
Likes: ggrizzard
Oct 27, 2024
21
Bed-it seems to come in 1/2" wide tape. Would I lay two (or more) strips side-by-side then tighten the rail down? Would I expect it squeeze out as it tightened? I remember a roll of this stuff in my dad's garage for the windows in our van. Seems like a forever solution.
No. Never do that. What you should do is roll it up into a ball, and heat it with your hands, and only then flatten it out and place the appropriated amount under each rail before you tighten the nuts&bolts.
Sep 24, 2018
4,819
Catalina 30 MKIII Chicago
Bed-IT. Instead of doing a bunch of elbow grease trying to clean up the fiberglass, just bevel the edge. Much less area to clean up now
-na -NA Anywhere USA
Hunter was infamous for using.5200 topsides. Taking out screws will be difficult. Do not consider 5200. Are you installing new teak?
21
Screws came out easily. Yes, I'm making new rails and new teak at the helm seat. I was concerned that once I got the old rails cleaned, brightened, and the roughness sanded out that they would be too thin. Found some nice stock at Woodcraft for both. I'm thinking of making the new rails slightly thicker.
