Anchor Type
Dec 7, 2024
25
MacGregor Venture 222 Traverse City
Hello all,
Currently -14 with the wind chill here in Traverse City, Michigan.
Venture 222
Noobie question. Will a 22# dansforth with 22' of chain be enough to keep me from moving when spending the night on the hook. In protected waters. Sand and some rock/gravel bottom.
Thank you all
Jan 7, 2011
5,906
Oday 322 East Chicago, IN
The ice will probably hold the boat still :poop:
I am wintering in SW Florida, and it is chilly with this polar vortex stretching all the way to the gulf…but I am still in shorts and flip flops today:cool:
I think you are ok with your anchor set up, assuming you have some rope rode after the chain…in other words, you need more than 22 feet of total anchor rode. Even in 10 feet of water, I would typically play out 30 feet of rode for a calm night. More if I have any wind.
I sail a 1988 O’Day 322 (about 12,000 pounds loaded) on the south end of Lake Michigan. I typically use a plow type anchor, about 25# I think. I have 2 danforth anchors as well, but don’t keep them on the bow.
When I anchor out on Lake Michigan, I select my weather window carefully. As you know, Lake Michigan can build 8, 10, 16 foot waves. So as long as you are on an inland lake, a protected bay or have off-shore breezes and calm seas, you should be good.
Are you sailing on LM or a smaller lake?
  • Ha
Likes: jpiombo67
Mar 27, 2024
49
Hunter 39 Wickford
Danforths will hold really well once set. For me they have always been very difficult to set. They also don't do well if the wind / tide changes direction. There are much better designs out there today. I have had really good luck with spade anchors. Set really well with in a 1 1/2 boat lengths and reset if the wind / tide changes. If you want to see a lot of test data on anchors check out SV Panope on YouTube: SV Panope
Likes: jpiombo67
Dec 7, 2024
25
Thanks for the laugh. Lucky you. I'm a Floridian who came up here 20 years ago and said, " This is a really nice place to live" Then winter came along and then family and here we are.
I mostly sail on W. and E. Traverse Bay, S.and N. Manitou Islands and an occasional trailer to Lake Superior. Always always find little coves and natural harbors that are protected from the elements. The reason I was thinking about the Dansforth is that it stores flat. I have 150' of rope attached to the chain. I try to stay in 10' to 12'.
My current setup is a couple of Byers, but they kind of drag around a little. I am hoping the Dansforth will sit better.
Dec 7, 2024
25
Thank you for the channel suggestion. Yes that is my apprehension getting it to set.
Jan 7, 2011
5,906
I like my old plow anchor better than the danforth…not sure if they are readily available used .
Lake anchoring can be challenging. Danforths work great in sand and mud, but a rock bed shore not so well. Snags are also a frustration, come time to haul anchor. Do you use a trip line in case an old tree root is down there? I like trip lines with a small buoy, because the buoy helps tell you where your anchor is.
-Will
A 22 lb anchor for a 22 foot boat is way over kill. An 8 or 12 lbs anchor will easily hold your boat.
What matters is what the bottom is like. Danforth's work well in sand and mud, so-so in gravel, and not at all in weeds.
The SV Panope YouTube channel has more information about anchors than you may care to know. Steve's videos are very instructive and worth watching.
JBP-PA
Apr 29, 2022
782
Jeanneau Tonic 23 Erie, PA
@dlochner is right, 22 lbs is overkill for a Venture 22. 22ft of chain is perfect for your boat on the Great Lakes. I prefer a bit more rope rode as my typical anchoring is in about 20 ft. +/-. As long as you anchor in mud or sand you'll have no problem. I have a 13 lb Danforth on my 23 ft boat and it does just fine for overnight use. I like 1/2 in anchor braid which is also overkill but it is easy on the hands. Watch some of the myriads of videos on how to set your anchor. Once it digs in it's really solid. If you are on gravel, if it sets you are OK, but if it skips along the bottom you should move elsewhere. Even if the bottom is rocky in part of a bay, there will often be another area that is mud.
I also use an anchor watch app as a backup warning. Especially since we tend to get wind shifts around midnight to a offshore breeze. Although I've never had my Danforth drag in a wind shift, it's good to stay aware of the possibility. Sometimes I'll set the anchor alarm to trip on the wind shift just so I can get up and check on things.
Danforths are much more popular on the Great Lakes than spade type anchors because we have a lot of sand and mud bottoms and they are fairly well charted. Spade anchors hold better in all conditions and reset well, but they are heavy and expensive and not really necessary (unless you leave your boat unattended for long periods).
Hello all,
Venture 222
Thank you all
What size chain is being used?
@thinwater has written a book on anchoring, You might find that helpful as you sort through all this information. It's available on Amazon here.
Dec 7, 2024
25
Thank-you for the input. I was looking on Marketplace. I just saw a listing for a 17# dansforth. I have 22' of 3/16th chain that is currently attached to my Byers type anchor. I was looking at spades, but it looks like they take up too much room.
I do have an anchor alarm on my GPS.
Likes: JBP-PA
17# is too big for your boat, unless you plan to anchor in hurricanes. ;)
  • Ha
Likes: jpiombo67
Defender has a 9# Genuine Danforth Anchor is which the size you need for $45. Not sure how much you would save on Marketplace.
The anchor you don't want looks like the photo below. They are designed for easy retrieval, the ring slides to the anchor flukes and the anchor comes out backwards. This also happens in a 180° wind shift, the anchor pulls out and won't reset. Fine for a lunch hook, but not for overnight.
Dec 7, 2024
25
Thank you. Just placed the order!!!! The ones I was looking at looked like the picture above.
Likes: JBP-PA
JBP-PA
Apr 29, 2022
782
I too lust after a nice Spade anchor, but I can't justify it.
After using Danforth style, a Delta plow, an original Bruce, and a Rocna, we mortgaged our house and bought a Spade. After several hundred nights at anchor, we are convinced it was worth every penny. The only times it would not set were in conditions that no anchor was going to set, thick weeds, shallow sand over limestone, and on top of a piece of plastic. Even in tidal currents, the anchor always set and reset with the current change, except when the opposing wind and current held the boat almost in the same position with the anchor just sitting on the bottom. And just kidding about the mortgage, the Spade isn't cheap, however if you anchor out a lot or have money burning a hole in your pocket they are worth it.
Likes: JBP-PA
ART005
Jun 24, 2020
4
San Juan San Juan 21 Canyon Ferry
My 26S came with an undersized Danforth, maybe prior stern anchor, and slightly oversized Bruce that was difficult to store and utilize. My 1st in horrible lake wind while single handling I made it to a partially protected bay, I deployed the Danforth because I could. It held, nerve wracking for hours. Got home and found it was 1 size too small. Increased chain and anchor and never had a second doubt. Gravel/sand, not much grass. 25% depth chain with 6ft minimum. Freshwater 4x Rhode to depth.
Don't kid yourself if you think you'll typically anchor in 15ft. Plan 25ft minimum.
