vent cap
Db421
Jun 7, 2004
95
Hunter 34 1986 Lake Lanier, GA
I've been looking for these small vent line caps for a while, but not sure where to look. I've tried google lense but all I get back are large dorade or exhaust line vent covers. These are 1/2"=3/4" tank vents. Anybody have a clue?
Likes: murrayabbott
The caps are part of the vent, they can not be replaced independent of the vent fitting.
Dec 2, 1997
9,007
- - LIttle Rock
Better yet, if we're talking about a holding tank vent thru-hull, forget about a cap for it. Replace the "vent" thru-hull with an open bulkhead (aka "mushroom") fitting. "Vent" thru-hulls are designed to keep sea water out of fuel and water tanks. They're totally unsuitable for use on holding tank vents because they don't let the tank "breathe" which is necessary to prevent odor from being created...but boat builders use 'em on holding tanks too 'cuz it costs them a little less than buying a different one for holding tanks. An open bulkhead fitting has another advantage: it allows you to put a hose nozzle against it to back flush the vent regularly to prevent vent blockages. Anything that tries to set up housekeeping in the vent line will get a water slide ride into the tank.
--Peggie
Likes: Db421
Jan 4, 2006
7,438
Past :
Brass vent caps corroded like crazy. Nickel plated brass (or bronze).
Present :
New ones are SS with internal loops of about 18" up to the underside of the deck.
With the internal NPT thread in the thru-hull, you can pull a quick upwards turn with a street ell 90° elbow and into a hose loop before heading off to the tank.
Db421
Jun 7, 2004
95
Past :
Present :
Thanks for info & pics. I never thought of these. They look great!
