Hi all, looking for feedback on my chainplates. Bought my '86 Oday 222 a couple years ago. Have seen a lot of discussion here about Oday 22-25 chainplates, and wanted to get feedback on how mine look. See pictures attached. The port chainplate looks to have had extensive dryrot in the chainplate mounting area of the bulkhead - it's almost entirely eaten away - I'm inferring that the previous owners added the metal straps shown that extend mounting point lower into the non-rotted bulkhead area. I'm wondering if the gelcoat crazing on the port chainplate indicates that one was about to fail - or conceivably actually failed and pulled through - which triggered the repair. Both chainplates don't leak in the rain (i've checked) although I'll reseal top next spring.
Anyways - the advise I'm looking for from this forum is: Does the repair method shown, with the extender straps tying the chainplate to non-rotted bulkhead area look ok? The bulkhead area where the extender metal straps are tied to looks solid (shocked at the thinness of the bulkhead plywood, however!) I know people suggest replacing oday 222 chainplates with e.g. oday 25 chainplates, and that is probably something i'll undertake in the next decade if I keep this boat and sail more often on larger waters, but just looking for some guidance on how my boat looks. Honest advice appreciated. Aware of the adage "if you're wondering if you should replace the chainplates, you should have already replaced the chainplates".
Thanks!!
Thanks!!
