Hi All,
I have a Dufour 34, 1975.
So far in life all the Marinas I have been had cleats, so I would motor in it.
Lay my premade loop which ran mid boat on the cleat, pull in the slack with the winch, cleat.
Put it in forward, then turn the wheel right and the boat would dock nicely.
I could then get off the boat, nice and calm, tie all my lines, go back, run my fresh water rinse routine and then turn it off.
What do you suggest to do if there is no cleat?
Well there are two cleats but only at the front.
At the back you have two rings.
I'm guessing I can leave a pre cut to length line.
With a big loop, tied to the ring.
Then approach, pick it up with the fishing pole , put it on my port cleat.
Anything you can recommend that would be more "relaxing".
The winds can pick up in the bay in summer.
Thank you
Thank you
