do I really need winches on my mac 26d?
Dec 7, 2024
5
Macgregor 26d Pollock. Payette lake
Just picked up a 1988 mac 26d. For me its upgrading to a "big Boat" It does not have winches but I see others that do.
Learn me please.
JBP-PA
Apr 29, 2022
481
Jeanneau Tonic 23 Erie, PA
You do not NEED winches, but they make trimming the jib much easier in heavy wind. Definitely used is much cheaper. Ebay always has some but you can find deals at marine consignment shops and junk shops too. If there are abandoned boats nearby, you might get permission to remove some. If you know someone in a big marina, ask them. Sometimes you can get them dirt cheap.
Likes: FDL S2
Sep 24, 2018
3,043
Catalina 30 MKIII Chicago
There's plenty of used marine places out there. Mass Marine and ebay are the first places that come to mind. I had a Starwind 19. That was just below the threshold for needing winches. My O'Day 25 absolutely needed them. There were multiple times that I grabbed a hold of the line while tacking and it pulled me across the seat!
RussC
Sep 11, 2015
1,594
Merit 22- Oregon lakes
You'll definitely want winches but you most likely won't use/need winch handles.
Sep 24, 2018
3,043
Only if he winds the sheet the wrong direction ;)
Every turn on a line increases resistance. I usually pull as much jib sheet in as I can by hand and then do the hard work with the winch. It's a good balance between speed and torque. Doing it all on the winch, even without a handle, is often harder and slower
FDL S2
Jun 29, 2014
478
S2 7.3 Fond du Lac
Winches don’t have to be super expensive. You can go the used route, but West marine has a BOGO sale on Lewmar winches every March. Lewmar #6 non self tailing winches are $197.99 right now, so if they have the sale you will be able to get two new winches for under $200 -that’s not a ton of money for something that is going to greatly improve your sailing experience.
Once you have winches you will also need a winch handle-I know you can do without it, but why? Amazon has a cheapy for $33. Or if that is too much, talk to sailors you know and tell them you need a handle. If they are anything like me they have a few old ones laying around that were replaced with one touch or floating handles and will probably give you one, or trade for a beer.
Dec 7, 2024
5
About those self tailing winches? Not needed for a small boat like a mac 26d? Even $400 for a pair of new would be great. Thank you
pgandw
Oct 14, 2023
92
Stuart (ODay) Mariner 19 Yeopim Creek
On a Mac 26d, self tailing winches would be more trouble than they are worth. Ideally, I would put a cam cleat behind the winch for quick release of the sheet when you need it. Ordinary sailing, 2-3 wraps on the winch is sufficient. This is from a former ODay 25 sailor.
There are no winches on my Mariner 19. Don't need them with just a working jib. Some folks rig a 2:1 purchase on the jib sheets, I haven't seen the need. If I had a jenny or spinnaker, I would need winches.
Fred W
Stuart Mariner 19 #4133
Dec 7, 2024
5
Fred W
[/QUOTE
I am so glad I found this forum. Thanks
