Need everyone’s opinion again.
I’m mounting a 9.9hp high trust outboard on a bobs machine shop motor jack, which is mounted into the transom of an oday 28. Hope you all follow so far.
Will post pictures of transon ( with old mount to be removed, and pictures similar to the mount I’m looking into.
What’s stronger and more solid if a mount, Wedges and have motor jack plate mounting bolts threw wedges and transon, or have built an aluminum angle plate similar to picture below where it would be mounted to transon and then jack plate bolted into it?
Will have either one fabricated, pictures are just so everyone has an idea of what I’m thinking.
