Soft Deck Safety
Nov 23, 2024
8
O'Day 39 Muskegon
Hi there- I'm currently looking into purchasing a 1983 O'Day 39. The boat is in apparently great condition- some minor cosmetic issues, but otherwise in very nice condition with no signs of intrusion (within the cabin), lots of recent upgrades/repairs, and was very well cared for being used for ASA courses over the past decade. I have a survey from last year done for insurance purposes as well as pre-purchase survey completed this week- and while a few other minor issues have been found (that will be fixed by seller) there is one that keeps coming up- moisture/delamination in a number of locations on the deck/ in the cockpit, including at the chainplates. The owner rebedded the deck hardware a few years ago, and it seems like that is a good start to mitigating the issues, but I'm having trouble finding a straight answer on the internet as to how severe of a concern this issue is. I understand that fixing the issue is something that could cost as much as the boat is worth- or more- but I can't find an answer as to whether this is an immediate safety issue, or this is something that could be addressed at some point down the road. It seems to be that most boats built before this century have this issue to some extent, and I'd love any advice/info as to how much of a concern (safety and resale-wise) this issue is.
I appreciate all of the help!
Thanks!
7,261
Alden 50 Sarasota, Florida
I doubt any 40 yr old boat doesn’t have/had some rebidding done along the way. But rebidding doesn’t fix the delamination or rot. In other words, rebedding mitigates nothing except further damage.
I have no knowledge of how and to what the chainplates are attached but I believe every Hunter ever made has a wood/balsa core above the WL and if correct and the material to which the chainplates are attached is damaged from water, I wouldn’t even consider buying it until the area(s) have been exposed, examined and thoroughly identified. Bad things happen when rigging fails.
If the plates are fixed to exposed bulkheads, examining the security of them is more straightforward.
While it would be best to have decks as dry today as they were when they were built, the reality in most older boats is that there is some wet core on the deck. Sooner or later the wood will completely rot and the deck will loose it structural integrity, but who knows when that day will come.
The chainplates should pass through the deck and not be attached to them without substantial attachment to the bulkhead or knee below the deck. The critical part of the chain plate is where it attaches to the bulkhead or knee. Rotted wood there is bad and can cause a structural failure.
Repairing wet core in small areas is not technically difficult, cut off the skin, dig out the rotted core, install new core, glass a new skin, and paint/gelcoat/apply nonskid. Time consuming, depending on the size, and that's were the expense comes in, labor isn't cheap unless it is yours.
May 1, 2011
4,664
Pearson 37 Lusby MD
:plus:
dLj
Mar 23, 2017
3,788
Thanks!
Got a survey map of where the moisture is found? Got numbers of % moisture in those areas? Without that kind of hard data nobody can answer your question. When were the chain plates replaced - if ever? Can you see the chain plates? Got photos?
The extent of moisture intrusion is needed to be known. The biggest concern from what you've said so far is the area of the chain plates. Having soft decks there indicates water intrusion in that area. Looking at the condition of the chain plates plus the attachments to the structure would be a safety issue.
dj
On their more midsize models I know O’Day anchored the upper and aft lower shrouds into the hull pan, but the forward lower shrouds only went to a plate embedded in the deck. I don’t know if they did the same on the larger 39, but if so any moisture in the deck would be a bigger concern to me.
Nov 23, 2024
8
O'Day 39 Muskegon
The former is true for the 39. The the upper and aft lower shrouds run all the way to the hull, but forward lower are terminated into the deck. Fittings themselves look to be in great condition as well as the actual shrouds.
Nov 23, 2024
8
O'Day 39 Muskegon
dj
Not a map, but I do have a list. Included on the list is both port and aft deck where the chainplates are bedded. I can reply with more info when I have the survey from this week in my hands as well, and I'm working to put together some pictures as well. The surveyor did not provide specific moisture readings, just stated that they were apparently elevated and that the sounds from the taps were indicative of delamination. That being said, two of the three shrouds are run into the hull, which is solid fiberglass on the '83 39. I appreciate your time and will respond with more info when I get the chance to get more pictures.
Nov 23, 2024
8
O'Day 39 Muskegon
Thank you for your response.
Two of the three chainplates are bedded into fiberglass bulkheads below/ behind the settees, with the forward lower bedded just into the hull. From what I can tell the connection is secure and there isn't any sign of issue with these connections. Pictures to follow.
7,261
The pictures will help us better understand the potential for any chainplates issues.
Our son had an Oday of that vintage with leak/ core rot/ delamination issues. Unfortunately, it was a while ago and I can’t recall specifically what was damaged because of water intrusion but his fix was to move the chainplates outboard to the topsides rather than attempt scarfing in new wood. On his boat, all chainplates were fixed to either wood bulkheads or wood glassed sandwich in the hull.
Jan 7, 2011
5,192
Oday 322 East Chicago, IN
On my 1988 322, both sets of shrouds are anchored through the deck to stringers attached to the hull (using round rods), and to the floor pan. You can see the 2 rods for the port shrouds in this photo.
higgs
Aug 24, 2005
3,687
Nassau 34 Olcott, NY
Lake Michigan is serious sailing where you are likely to encounter some serious loads on your rig. Those forward shrouds would be a big concern to me. How far the wet balsa goes is the big issue. If it is just a couple inches that is not too bad of a fix. More than that you are looking at a lot more work.
Nov 23, 2024
8
O'Day 39 Muskegon
See attached from the survey. Unfortunately I don't have a picture of where the chainplates interface with the hull at the moment.
Nov 23, 2024
8
O'Day 39 Muskegon
I know that well, I've sailed the great lakes on my smaller boat for a few years now. Is the most reliable way to measure the extent to drill holes, or is the moisture meter reliable enough?
