Ellebogen Isolators
Aug 7, 2021
98
O'day 28 Casco Bay
My 1985 O'day 28 was re-powered with a Yanmar 3GM30F. The engine has a DOM of 1994, so I'm thinking is was done in '94 or 95. It appears that the mounts are original so I have decided to replace them. OEM mounts are crazy expensive. Does anyone have any experience with Ellebogen mounts from Spain? Website is very good and I was able to download drawings of the replacement isolators I need. They are dimensionally identical to the OEM ones and have a good warranty.
Any reason you think they need replacement other than age which is just a number.
Well, if you have ever had an engine mount fail in rough seas, as I have, planned maintenance would seem prudent. I don't know which type of Yanmar mounts the OP has but, on the 'inerted V' ones, the bond of the rubber blocks to the steel eventually fails.
Likes: Clutch Cargo
Aug 7, 2021
98
O'day 28 Casco Bay
"Age is just a number" is a faulty premise and in my experience in both the commercial and recreational marine world has lead to more than one catastrophic failure. Jim Legere makes an excellent point and mine are indeed the inverted "V" type.
Diesel manufacturers usually publish a replacement schedule for isolators and some in the recreational space are what I would consider excessive. I've seen some Yanmar manuals that recommend every 4 years or 1000 hours.
In my case, I'm doing it as a preventative measure in combination with some other work around the stern tube.
Feb 10, 2004
4,065
Hunter 40.5 Warwick, RI
If you ever have a failure on the engine involving cracking, Yanmar may be dis-inclined to honor any claim if you are not using their mounts. Maine Sail has info on this with his Westerbeke engine.
Aug 7, 2021
98
O'day 28 Casco Bay
LOL! Yanmar isn't going to entertain any warranty claims related to a 30 year old engine in a 39 year old boat!
