Best way to get a clean cut on a wire reinforced hose?
During the install of my exhaust hose, the mechanic and I used a sharp serrated knife on the hose and wire dikes to snip the imbedded wire.
Likes: Justin_NSA
angle grinder
That could develop a foul smelling smoke as it burns its way through the hose. Perfect is not needed. The hose generally fits over a long pipe tail. Plenty of room for double hose clamps.
Nov 6, 2006
9,995
A box knife and some good wire cutters .. The wire is really hard stuff.. I reckon a small angle grinder may work better on the wire than wire cutters.. but as John says the rubber would not be fun to do with a grinder.
Ward H
Nov 7, 2011
3,750
I use a box cutter type knife to hack saw to cut the rubber, then I use a Dremel with a cutting blade to cut the wire just under the surface of the cut rubber.
Oct 13, 2020
155
catalina C-22 4980 channel islands CA
I found this video when I was replacing my sanitation hoses. The key is the pair of cutters that he uses, although Ward H’s method using a dremel tool is very similar. It worked great straight cuts and no sharp edges
Dano
Likes: Indysailor
Jan 4, 2006
6,950
Maybe I'm living in the Stone Age because the only tool I use is a hacksaw with 32 TPI (teeth per inch) blade. Produces a smooth cut with the wire nicely laying down into the rubber. Any lower TPI and it looks like a saber tooth tiger chewed the end off.
I think this may be the problem with others who have cursed the hack saw. Only a fresh blade with 32 TPI produces a flawless cut. Start cutting between two wires on top of the hose so that the single wire is near a solid surface on the bottom (doesn't wiggle) when it's being cut.
Likes: Rich Stidger
