Hi all! I just bought a new boat and am looking for input on how the plumbing is set up, which I've diagramed below. Here are the three flows I see, but I could use your help answer a question or two to confirm the role of the manual pump.
1. Tank stored waste: from the head, waste flows from the head on the red line to the 3-way. When the 3-way is set in the tank position, waste flows to tank when pumped from head
2. During pump out: pumping out from the deck, waste gets sucked out of the tank on the blue lines.
Question: is the manual pump a one-way, so the pump-out suction is blocked at the end of the green line, and so just sucks from the blue line(s)?
3. Offshore waste dumping
Question: how does this work? Where does the manual pump come into play?
Thank you!
Thank you!
