The OEM bilge pump in my 2002 Catalina 310 is not functioning well and I plan to replace it with a new Whale bilge pump from Catalina Direct. I also plan to run a new hose to the bilge. I have two questions: 1.) Has anyone replaced their bilge pump hose and, if so, how difficult was it to run the hose from the aft port lazarette, where the pump is mounted, to the bilge? How hard was it to remove the old hose? 2.) The end of the old hose has a strainer attached. I've attached a picture of it. I can't find a replacement for the original strainer anywhere so I plan to replace it with the Whale bilge pump strainer in the final picture. Does this seem like an appropriate strainer for the manual pump?
