I was looking at a friends 1994 Beneteau First 210 and found a 4' x 7' area aft of the keel that flexed fairly significantly when I pressed inward on the hull with the bottom of my hammer. To my knowledge these hulls are not cored and the laminate seems to be very thin which I believe was intended to save on weight. I believe what I am seeing is oil canning. My question is, is this a concern and has anyone seen this before on this particular model? It seems the hull bottom is built very thin but particularly so aft of the keel in the area I have circled in red.
