Dripping Jabsco Selector Handle
Sep 26, 2008
777
Hunter 340 0 Wickford, RI
I replaced my Jabsco Toilet Pump Handle Assembly a year ago. This year I have a very annoying drip of Seawater at the Selector Handle. It‘s not a flood of water but it is enough to have to wipe it up. Every time it is used. Regardless of the position, bring water in or exhaust water out to holding tank.
What’s inside there and can it be replaced? Or is it a compete Handle assembly replacement ?
5,475
Pearson 37 Lusby MD
If I recall, the service kit contains a new gasket/flapper for the selector. Here's the part number for the kit I use: 29045-300 for toilets 29090/29120-3000.
Likes: JoeWhite
Nov 6, 2006
10,219
If the water is leaking out of the selector switch shaft, that seal is just an o-ring ..It could be found at an Ace Hardware or Depot or Lowes..
Kappy is correct on the service kit.. it does contain that small o-riing as well as the other stuff.. The flapper gasket may be leaking in that area..
Jan 4, 2006
7,650
The problem is that O ring #22 is leaking.
Initially, slather the old O ring with a NON-PETROLEUM grease such as SuperLube :
........... and see if that works.
If not, see if you can find a replacement O ring at a hardware store or Amazon. The Jabsco repair kit is about the same price as a whole new head.
If you can't find the correct size O ring, fabricate the correct size from an oversize O ring using Krazy Glue to adhese the ends. Check You Tube for some ideas
Likes: kloudie1
Oct 13, 2020
204
catalina C-22 4980 channel islands CA
Rebuilding is not hard. The cost of a rebuild kit is about 1/3 the cost of a new head. $80 to $90 bucks vs $260 or so for a new head. There are several good youtube video showing the rebuild.
Dano
Sep 26, 2008
777
Got to that annoying drip of seawater this morning.
It had to be me. As hard as I looked I couldn’t find anyone to blame this on.
I had every intention of replacing the O Ring and be on my way.
Here are the photos of what I found.
How, I don’t know, but somehow just didn’t get the water out and the antifreeze in last year. And it wasn’t a particularly cold winter. Rather mild if I remember correctly.
My word of advice, don’t leave out the removal of the intake hose and pump through the antifreeze. I don’t remember how much antifreeze I used, but obviously it wasn’t enough.
7,650
What a miserable, rotten, SOB to have that happen. I doubt that it's even worth trying to get some crazy glue in there to see if that will seal the leak.
My condolences :mad:.
Sep 26, 2008
777
I have a new one on the way, as we speak. Thank you for your condolences. Amazing what a small amount of water can do.
