Hi Folks,
I'm new to the forum, (Hi everyone) and recently purchased a 1999 Hunter 340 'down under' here in Brisbane - Australia. The marine survey showed signs of considerable water ingress in the rudder blade. Hoping someone could please advise the most likely 'factory composition' of the rudder on this particular model/year? (I'm guessing it would be glass over foam?) Are there a series of SS tangs off the trailing edge of the rudder post? Also, (unrelated) there are two thru hull skin fittings with seacocks in the starboard transom locker. These are not connected to anything. Could these possibly be for a non-existant AirCon unit which I believe was a factory fitted option in these boats. They're badly seized, so will probably be removed and the holes professionally 'plugged'. Thank you in advance for any info... and happy 'Huntering' (I already love this boat!) Mark Mac - Brisbane, Australia.
