Replacing Maxwell 500 Windlass
Apr 17, 2013
182
Catalina 310 57 Pompano Beach, FL
Looking to replace my original windlass with one that will take chain. I want to put it in the same opening as the original one. Has anyone done that.
Thanks,
Mark
Jan 4, 2006
7,870
If you'll post several pictures of your current setup, those of us who don't have Cats will tell you which windlass will fit.
Feb 20, 2013
52
Catalina 310 Channel Islands Harbor
Mark,
I was able to upgrade the windlass on my boat. Due to the shape of our chain locker it does not work well.
There just is not enough of a vertical drop for the chain. I tried installing rollers and guides to get the chain to not jump the gypsy when raising the last 50 to 100 feet of chain. Nothing worked until I used a piece of 2x4 between the gypsy and the bulkhead. Not optimum but it does work well. I have 150' of 5/16" chain, usually anchor in 30' of water.
Installation was not that hard, did have to enlarge the opening. It has been a few years since the install, don't remember any issue with the bolts. This is the Maxwell VW1000.
Hope that helps, let us know how your project goes.
Jeff
Apr 17, 2013
182
Mark,
Jeff
View attachment 228018View attachment 228019View attachment 228020View attachment 228021I
Thanks so much for the reply, I will look into the Maxwell VW1000. I only use 85' of chain my cruising is in the Bahamas max depth 15' in anchorages. Is this setup for only one direction pulling up the chain?
Feb 20, 2013
52
Yes, just like the original it is up only. Did not want to get into a rewire project.
Jeff
SJN
May 30, 2021
43
Catalina C310 Seattle
Hello Mark. Where is the 2x4? I do not see it in photos.
Stephen Nielsen
310 number 260
D
Deleted member 117556
I am interested in this project also. Right now I use the original Maxwell 500 windlass to assist retrieval of 5/16" chain. I have 120 ft of chain and typically use between 60-80 feet while anchoring mostly in Florida. It works OK but a chain gypsy would be better just not sure if that is realistic with the limited vertical drop. Wonder if any 310 owners have solved this?
Feb 20, 2013
52
I use a scrap piece about 2' long and just slide one end between the gypsy and the bulkhead to keep the chain from jumping off the aft side of the gypsy and to keep fingers far away. Like I said not great but it does work.
Apr 17, 2013
182
One more question did you use the original 4G wire, it looks like I will be buying this windlass.
Thanks,
Mark
Feb 20, 2013
52
Mark,
Yes, I used the original wire. So far it has worked fine.
Jeff
Apr 17, 2013
182
Mark,
Jeff
Just getting ready to install this weekend. Did you use the chain stripper or remove it?
Thanks,
Mark
