Hi all,
This question may be somewhat Legend 35 specific (mine is an '87).
I want to replace the 2 hoses that run from the engine, under the liner for a distance, and back up under the galley sink area, and then finally over to the nearby waterheater.
The problem is that tugging them from either the engine compartment (where they go through a hole in the grid system, or from where they emerge under the sink, they don't seem to budge. My concern is that they may be zip tied to the underside of the grid system before assembly and that is will be a real fight to extract them, let alone getting new ones back in. (using a endoscope camera, I was able to see that other things were zip tied under there, like the 120V wiring, and maybe other things.
My thought was that if they moved freely, then I could use a coupler to used the old hoses to pull in the new ones.
