Skipper II help please
CCC
Aug 27, 2024
6
DYER DYER 40 Whitefish Bay WI
I have just acquired a wonderful boat. A 1961nDyer 40 named Blue Pigeon. It has a WC Skipper II head.
I have what looks like a couple of new repairs kits for parts and spares
My problem.
When I shut the intake hose and open the discharge hose to empty the tank, water still come into the bowl
thought the interior rim. I can empty it all. close the discharge sea cock and water will slower seep into the bowl. I can't seem
to empty it and keep the bowl dry
So when I'm bouncing around water is splashing out of the head and getting my sole wet.
What am I doing wrong and or what is malfunctioning with the head.
Thanks Thanks
CCC
May 1, 2011
5,284
Pearson 37 Lusby MD
My first suspect is the joker valve. Any idea when the head was last serviced?
Welcome to the forum! :beer:
CCC
Aug 27, 2024
6
Hi All
Thank you for opportunity to join such a fine group.
To your question, no I don't.
CCC
Aug 27, 2024
6
Is water supposed to be coming into the bowl when I have the intake hose closed
and I'm pumping to just trying to empty the bowl?
Apr 25, 2024
715
Fuji 32 Bellingham
When you talk about the discharge hose, are you talking about the hose to a through-hull below the waterline? In other words, are you dumping directly overboard? Into Lake Michigan?
CCC
Aug 27, 2024
6
No, loops into and valves into a holding tank. There was an option to discharge directly as the boat has spent its 63 years in salt water on the East coast, that option is no longer available.
The Coast Guard has given me an inspection and CLEAN bill of health.
May 1, 2011
5,284
Pearson 37 Lusby MD
No. This is why I suspect the joker valve needs to be replaced.
Jun 11, 2004
1,862
Oday 31 Redondo Beach
Just a thought but are you sure the valve to close the intake is working and fully shutting off the intake?
Do you have a vented loop between the pump and the bowl that is higher than the boat's waterline?
CCC
Aug 27, 2024
6
I know the loop is higher
I have to check the valve and see that it is working properly
Thank you
Apr 25, 2024
715
Fuji 32 Bellingham
OK, I re-read your post, and I think I understand now. Just to be clear, you are saying that you suspect a leak somewhere along the intake line?
What isn't clear to me is this:
Let's say you completely empty the holding tank and pump the head as dry as you can. Over time, will the holding tank fill up, even if the head is not in use? Over time, will the bowl fill up, even if not in use?
Or, are you saying that, when you get liquid in the holding tank, it will slowly leak into the bowl?
It sounds like you are saying that you empty everything, yet water is coming into the boat and making its way to the bowl. Is this correct? If so, is it going into the holding tank and, from there, into the bowl? Or, just to the bowl?
In any case, if water is coming into the boat that you are not actively pumping in, then that's potentially an emergency. It just isn't clear to me where the water is coming from - from outside the boat, or just from the holding tank.
If the issue is simply that you can't quite pump all liquid out of the bowl, or if you do, that some seeps back from the tank, that isn't necessarily a big problem. Every head I have ever had exhibited a bit of this. There is always a little bit of fluid way down there. The pump never completely pumps the bowl dry. If it fills up with more than a little bit way down at the bottom, I would assume that it would eventually fill to the level equal to the level in the holding tank ... which probably isn't something you want.
This would indicate a leaking joker valve, as suggested. Liquid is flowing from the holding tank into the bowl.
But, that isn't what I am inferring from your description. It sounds more like you are saying that water is ingressing, probably via the intake line, not via the holding tank.
If that is the case, I would expect the bowl to continue to fill until reaching the water level outside the boat ... which might well slowly sink your boat.
How long is the hose between the pump and the bowl? If the that hose is installed properly it will rise above the waterline and then down to the bowl. Water in that hose will drain into the bowl even with the intake valve closed.
It would be prudent to begin thinking about a new toilet. WC has been out of business for years and parts, likes joker valves and seals will be difficult if not impossible to find.
CCC
Aug 27, 2024
6
Thank you all
I think I have plenty to go on now. Intake hose is very short right from the shut off valve to the to the head.
I'm going to check to see if it's leaking then install a new joker valve. I've got a couple. Look for something obvious. If it is still not working. I' going to install a new electric head fed with fresh water from my on board water supply. I did that on my sailboat and it is clean and odor free. and safe. Thanks again This thread is closed
CCC
Likes: Rick D
