I am a little afraid to ask this question, for fear of the answer.
I attached 3 pictures of my bilge. The bilge is separated into compartments by what I believe are stringers? The first picture shows the bilge with a small hole that allows liquid to go through the stringer. You can barely see it in the picture. It is right at the water level. When I stick my finger in the hole and feel along the 'wall' of the hole, it feels like soft wood instead of hard fiberglass. If there is a wood stringer in there, it seems like it should be protected from any water...
The second picture shows cracks in the fiberglass that would allow water in if the level got higher. The same with the 3rd picture.
Do I have a problem?
Thanks!
Thanks!
