CITRISTRIP to strip varnish?
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
Has anyone used this stuff to strip the varnish off teak on deck? Results?
CitriStrip-Paint-Varnish-Stripping-Gel-Citrus-Scent-1-Quart_ecb581a2-0af4-447b-8005-f589e22c8...jpeg
I use it for varnish…. For bottom paint I use my own homemade peel away formula
Here is a before strip, an after strip, and an after sand/revarnish
jviss
Feb 5, 2004
7,089
I just want to do my toerails and taffrail. I was thinking I'd mask off, strip it with this stuff, sand, clean, etc., and then use Cetol.
Aug 28, 2006
578
Bavaria 35E seattle
It works, but it's tedious.....it's not magic. It will take multiple applications if the varnish is reasonably thick.
Likes: rgranger
Heat gun and a thin, flexible 'putty knife' is my go-to for varnish removal. Give it a try.
Likes: rgranger
jviss
Feb 5, 2004
7,089
I've heard that, it really works? It sounds a lot less messy than the stripper. Do you still have to mask?
It does work well. You have keep the heat moving , just ahead of the putty knife. Flats are easy; on handrails and curved surfaces you have to be careful not to use too much pressure to avoid gouging (not really any different than when using a chemical stripper). No objectionable odour, like you get working with chemical strippers that have a strong solvent base. Not my picture, but one from a good DIY varnisher in Maine:
Likes: rgranger
