Bilge Keel on a hunter 22
A bilge keel boat.
I have not seen a Hunter 22 with this configuration. At least not a factory item. I guess it could be done.
Sounds ambitious. I think it would take a lot of work to reinforce both sides of the hull to handle the lateral and vertical loads. For a boat that isn’t designed for it a lot of re-engineering would be needed.
Jul 1, 2024
3
Hunter 22 Panacea
I think what has happened is that the previous owner deleted the swing keel that the boat originally had and glassed over the opening. I'm at a loss, I can't imagine the boat sailing worth a dam without a keel, but the guy I bought it from says it does just fine downwind... sigh... I like the idea of having a boat I can beach but will look at what I have to do to add a swing keel back. I was thinking if I did some very short bilge keels I would just through bolt some on and run a wood ledger on the inside of the hull then fully glass the outside. I even thought about some thick aluminum plate keels on a flat curved belly flange, through bolt to a wood ledger board on the inside of the bilge and then completely glass it all in. Damnit Jim, I'm only an building Architect, not a marine Architect.
The PO removed the keel? We’ve read about some interesting PO shenanigans here before but that’s next level. :facepalm:
According to sailboatdata the Hunter 22 should have 1300 pounds of ballast. If the swing keel and its ballast are gone you’ll be missing the lateral resistance the keel provides going upwind, but more importantly the stability that weight provides. When keelboats lose their keels they can turtle pretty easily.
The problem with adding the bilge keels the way you’re thinking is that the glass in those areas is probably quite thin, as it’s not meant to carry any real load. There was a poster here a few days ago with a boat showing how he could deflect part of the hull just by pushing on it. I can’t remember what model boat that was but they’re generally all similar - the glass outside of the point of the bow and the keel support structure is just thick enough to keep water out, and not many pounds more. Even if you add backing boards you’ll have hard points wherever they end. I suppose there’d be a way to add the strength necessary but it’d take real load calculations and work to tie everything together.
Likes: LloydB
So, is the swing keel still in the boat and glassed over or is it completely gone? If it is glassed over, remove the glass and re-rig the swing keel. If it is gone, the boat is pretty worthless and dangerous to sail as @Davidasailor26 has pointed out.
As for beaching a 3,200 lb boat, it will be a bear to get off the beach, you would be totally dependent on the tide. The other issue is the rudder which is generally about the same depth as the keel. Shortening the keel would require shortening the rudder which will also affect sailing performance.
I am hoping this was a free boat you acquired and are now trying to figure out how to make it usable. Without the keel and ballast, what you got acts pretty much like a building without a foundation.
As @Davidasailor26 shares, the hull will act like a canoe. Not foundation to stop it from rocking. Lean on the side and the canoe flips spilling the contents into the water.
Your bilge keel idea is out of the box thinking. You would need to create an internal structure that allows you to build your keels. It would test your architect skills and likely improve your fiberglass building technique. You would end up with a boat that might sail down wind or off the wind, but struggle to go to windward.
There is an upper crust saying.. "Gentlemen never sail to windward"
Likes: Timm R Oday25
-na -NA Anywhere USA
You all guessed wrong. The twin keel Hunter is a British built boat built by a different company called Hunter. When Hunter Marine set up shop in England, it was called Hunter Legend as the name of Hunter was already taken. Not sure of the tidal action in Britain but the twin keels sure does keep the boat upright
PaulK
Dec 1, 2009
1,541
Sabre 402 Southport, CT
Hunter Legend may have built a twin keeled 22 footer, but the OP says his boat had a swing keel that was glassed over -- not the same. Going back to the swing keel would be the simplest option. Then if he still wants to beach the boat he could try to rig up crutches attached to the gunwales to hold her level. That might also require some engineering to handle the forces involved, but it can be done.
Hunter Marine and Hunter legend never built a twin keel boat. The two pictures show different configurations of side windows. I do question the OP claim. First start giving us a complete hull number in question and photos of the hull. Anything is possible but Warren Luhrs once said he would never build twin keel boats. Warren owned Hunter Marine in
The pics were not from the OP. They were from other posters suggesting what bilge keels and crutches look like on other boat models for comparison. Sounds like the OP’s boat is just an ordinary Hunter 22 with the swing keel “deleted”.
@Davidasailor26
it would be a momentous job to put twin keels on a hull which is why I requested a hull number and pictures of the specific boat. @Darwinless needs to provide that as i question this. My dealership replaced damaged keels of various sizes and several with different keels which is very expensive. However the Hunter Marine and Hunter Legend I knew never built twin keel boats
Jul 1, 2024
3
Hunter 22 Panacea
Thanks for all the words guys! The boat is currently on a trailer in Panacea Fl and I live an hour away, so next I go down and bring it the rest of the way home I will give all the info you guys are requesting on it. I will also provide more extensive photos as I go along. It was indeed a free boat as it came with a trolling motor and three good large marine batteries, so basically I figure the 100 bucks I paid is for those and I can do whatever with the boat. I already had a two axle trailer. I noticed some pictures with these on a single axle trailer. What do you guys trailer the boat on? It still has its ballast and the former owner sailed it from Panama city to where I picked it up at mash sands so I geuss it works with what it has. I design buildings to not pick up and fly off so I figure if I do anythihng it will probably be well over engineered. I will plan hard berore I do anything to it and look forward to any input you guys put in. Thanks again in advance.
