Hello all! Long time listener first time caller,
I recently purchased a 1977 Pearson 10m (33ft) with an atomic 4 gas engine. While taking the boat out for a sail for it's first time we started taking on water. After getting back to the harbor and inspecting it, we found a substantial leak coming from the rubber hose connecting the packing gland on the prop shaft to the hull.
Let me know if there's any more information I can provide other than photos. Not sure if related but it's been having an issue while in gear. It revs up fine in neutral and sometimes reverse, but when I put it into idle it seems to not be able to rev up beyond idle speed. There's also been some smoke coming from the engine while running in forward, have not been able to locate where exactly that is coming from.
The main questions that I would love y'alls opinion and expertise on.
1. Do you think this is a matter of the rubber hose slipping off, or the prop shaft moving forward and getting misaligned? (I read that can sometimes happen if the prop is jammed with barnacles and other debris)
2.What are some temporary fixes you would recommend? Moving the rubber hose up the packing gland coupling? getting another rubber hose to clamp over it?
3. What does this look like for a long term repair? Is prop movement/ realignment is fixable in the water. Could this indicate more severe transmission/ prop shaft repairs?
4. Does this something that would require taking the boat out of the water to properly repair it? Or is it something that we could stop the leak and still sail it? (we have a 10hp outboard engine that we can power the boat with)
Thank you for your response's in advance!!
Here are some photos of the leak:
From a different angle:
he's actually in now and where he will be headed until he lays out some significant money and/or labour. I hope he didn't go elsewhere looking for a more appealing answer. Feel sorry for the guy.
