Hi All,
Based on this.
I have an MKIII
It has a Screw
It has Four openings with 2 for lines.
The manual is here.
I read it and it says my furling line needs to be.
Page 5
Furling line is not included with furling unit. Purchase
7/16" (12 mm) low stretch Dacron double braid.
I purchased
7/16" Dia. Color-Coded Sta-Set, Sold by the Foot, Black
Model #353003
Mfg #2104-14-00600
Item 1.
When I got it I measured it using calipers and it is 10.6 not 12 mm.
Item 2.
I had a look at the line I removed from the sailboat which kept jamming.
It was roughly 8mm , which seems to be 5/16.
My question is ?
Was the previous owner clueless and put the wrong size line in.
If you have an MKIII Furler what furling line do you use ?
Based on this.
I have an MKIII
It has a Screw
The manual is here.
Page 5
I purchased
Model #353003
Mfg #2104-14-00600
Item 1.
Item 2.
My question is ?
