Do you have a 12-volt plug in the cockpit?i'm thinking the best source of electricity would be the pedestal where all the instruments are and then maybe I could attach a light to the 1 1/4 inch railing around the instruments?
I will look around but I have never seen one. it seems the pedestal instrument cluster is the best source of electricity I'm going to find.Do you have a 12-volt plug in the cockpit?
are you suggesting I run a new wire from the circuit breaker box? I tried that once and did not find an easy way to pull the wire through the boat that farYou probably don't want to tap into the 12v wires to the instruments. Is there enough room in the pedestal to run additional wires to provide a power source (12v plug/USB/etc.) for the light you want to install?
Yes. I didn't say it would be easy!.are you suggesting I run a new wire from the circuit breaker box? I tried that once and did not find an easy way to pull the wire through the boat that far
OK I guess there's no point in making this a more complicated project that needs to be. I ordered a light from Amazon. Thanks for the help guys!We use one of these hung from the bimini bow.. works well.
Amazon.com: MPOWERD Luci Outdoor 2.0: Solar Inflatable Lantern, 75 Lumens, Clear Finish with White LEDs, Lasts Up to 24 hrs, Waterproof, Camping, Backpacking, Travel and Emergency Kits : Sports & Outdoors
What kind of instruments are they? If they're just NMEA-2000 / Seatalk-NG units there might not be usable 12V there; the NMEA cables provide power and data together for instruments and sensors.I would rather have a permanent installation but a hanging camping light or tent light would certainly work im sure. i'm thinking the best source of electricity would be the pedestal where all the instruments are and then maybe I could attach a light to the 1 1/4 inch railing around the instruments?
