Portlight Polish
Feb 16, 2021
544
Hunter Legend 35.5 Bellingham
Does anyone have any tips or recommendations for restoring cloudy port lights? I also have 2 beckons that I can remove and polish (the rest are built into the deck).
I've used that stuff on my car headlights. It worked as advertised.
About a year later, they needed a repeat. I suspect a UV-inhibited polish or covers might help
Same
I suspect that part of the “ magic” is actually a wax with a similar refractive index that fills in the scratches instead of a polish that removes the scratch.
Sep 7, 2022
70
Captiva Yachts Sanibel 18 Lake Wylie
I used Novus Plastic Clean and Shine on my Gray Industries portlights. They have four grades of abrasive; I think I used a little of each. There was about an 85% improvement over the the clouding in 30+ -year-old lenses. Not as good as new, but much better. Still look better after a year or two.
I have hence decided to replace the entire portlights, since I have the space and time, but now that I have removed the fasteners, I'm having trouble breaking away the epoxy or whatever is holding the portlight to the fiberglass. Suggestions, anyone?
dLj
Mar 23, 2017
5,257
After polishing you need to use clear spray paint that has UV resistance.
dj
  • Wow
Likes: JamesG161
Feb 16, 2021
544
So use some headlight lens restorer followed up with clear spray acrylic UV coating?
dLj
Mar 23, 2017
5,257
All of these lenses have a UV coating on them. When they degrade and you repolish, you remove (or the degradation removed) that original UV resistant coating. So after polishing to get rid of scratches, you need to apply a new UV resistant coating.
You can use headlamp restorer if you want. You can also use polishing compounds. Most headlamp restorers I've seen are just glorified polishing compounds. In any case, once you've polished the lense - you need UV protection.
dj
Likes: Bob S
Jun 21, 2004
3,225
Beneteau 343 Slidell, LA
Here are some before and after pictures of me polishing a port, and the acrylic companionway hatch, for my Hunter 26.
Very nice results. Did you machine polish with foam or wool or did you hand polish? I need to work on my companionway hatch & acrylic hatch boards.
Likes: rgranger
I used a cheap buffer from Auto Zone.
Likes: BigEasy
When I sold the boat four years later, the ports were still clear. I did not use any UV protective spray.
dLj
Mar 23, 2017
5,257
It can be your lenses were UV stabilized.material, not just coated with UV resistant coating - that's a more expensive lens material usually. Or your UV exposure wasn't heavy. 4 years isn't that long. Automotive head light lens material is usually coated. Boat lenses - luck of the draw I'd guess...
dj
