Wing Keel on a 1988 Hunter 335
May 28, 2024
3
Hunter 335 Solomons, MD
Hi, all
First-time boat buyer, please be gentle. I've done a lot of searching and have not found anything valuable. The trailing edge of the wing portion of the keel is very jagged and not a smooth, straight edge. I understand these keels are cast iron. I was just wondering if this is typical; how soon is a repair in my future, or is it of no concern? The keel was just serviced before I bought it.
Hull - Keel - Repair: Ream out caulk between keel and hull, dry out, and recaulk. Scrape & Wire brush keel, treat with Ospho. Apply Interlux Interprotect 2000e Barrier Coating. Apply one coat on Micron CSC anti-fouling paint. (The second coat is included in HS10420 - Bottom Paint)
Likes: Jkutyna
Welcome to the SBO forum.
Perspective is needed as you look at mature boats. There are bound to be nicks and dings on a boat that is 36 years old. That is 63 in boat years.
The damage in the picture is superficial. You are unlikely to be racing the boat in international events where every tenth of a second is considered. I would look at that as one day, during the winter months, when I take my boat out of the water, I'll dress up the edge of the wing. One day may never come, as boat ownership will mean creating a list of tasks you need to or want to do to the boat. If and when you haul the boat, if you see rust stains, that is when this project will be moved up the priority list.
Good luck with the search for "your" boat.
Likes: TomStewart50
With an iron keel rust is the concern. Whenever there is a fresh paint job you should ask -Why? I would expect that trailing edge was rusted.
This keel looks pretty well cared for. I wouldn't delay a launch this season for only that reason. But next off season I would want to go down to metal and treat it correctly. But just for the trailing edge and about 6 inches up the fin or until there is clean metal.
I've been told that the best hydrodynamic end of the trailing edge isn't a feather edge. Supposedly a bevel is better. I have no idea why.
Sep 15, 2023
18
Hunter 33.5 Green Cove Springs
Yours is in better shape than mine. I have yet to have the keel addressed on my 33.5 I bought last fall. Hoping perhaps late this fall or early spring to take it to an actual yard where they can do the work for you, as this is beyond my technical means and scope and I want it done properly as the keel is such an important part of the boat. I don't have rust issues on the horizontal planes of the keel, but I do have degradation on the vertical aft edge of it. I can tell it's going to take a good bit of grinding there to get it all down to bare metal. Will see what I'm up against when the boatyard looks at it and gives me a cost and time frame. I have a slight "catalina smile" on the after end of my keel where it joins the hull, so not sure if the PO backed into something with it, or if this is just settling as the boat has been on the hard for 5 years now. Could be many things.
As was said previously though, for boats that are 30+ years old, we aren't going to be expecting perfection here.
If your keel has not found mud, you are not sailing enough.
Likes: TomStewart50
Hunter 30_88-94 Ipswich, Ma MA
I have to same keel. It may have been rust or it may have come out of the cast like that and then glassed smooth. The keel looks to be in good shape. Either way, it’s not an issue.
Likes: TomStewart50
