Has anyone found an alternative fresh water pump to the Shurflo Aqua-King II 3 gpm pump for their C-310? One that fits the same but lasts longer?
No accumulator tank. My pump is fine but seems to have about a 4 year life and then it slowly dies. I have become used to that with Jabsco products which is why I wonder about alternatives. However I am very cautious with alternate products because installation could be tricky. Very small tolerances on many items on my boat...Johnson makes some similar sized pumps, don't know if they are drop-ins.
I've had an Aqua-King pump for years with problems. What's happening with yours? Do you have an accumulator tank?
On the larger Aqua Kings it is not necessary to replace the entire pump, the pump assembly alone can be replaced. This is less expensive than replacing the entire pump.No accumulator tank. My pump is fine but seems to have about a 4 year life and then it slowly dies. I have become used to that with Jabsco products which is why I wonder about alternatives. However I am very cautious with alternate products because installation could be tricky. Very small tolerances on many items on my boat...
Thanks I'll look at that.Replaced mine with a shurflo pentair model 4008. 55 psi and 3 gpm and it does not require an accumulator tank due to a diaphragm pumping system. Works great keeps the admiral happy and zero maintenance for me. Made in Mexico.
