Maybe we have earned it
Does May promise to be a reward? Rufus says we will see sunshine.
Monday May 6
Only two damp, chilly days to go until --> ☀ Lots of Sunshine ☀
A long-waited WARM-UP arrives soon. But first, cold air moving in today - Monday - presenting showers & thunderstorms across much of the region. On & off peaks of sun between the showers, but the air will remain quite chilly for May. That all changes abruptly on Wed May 8. High pressure ridge begins to build up over the PNW, ushering in the WARMEST stretch of weather thus far in 2024!
Indeed, sunshine returns, with warming each day later this week. Current projections are for temps on Fri & Sat popping up into the 80s. (Some model runs even hint at a chance for a 90+ here & there about the PNW.) The coming weekend looks absolutely awesome. Dry & warm. Temps may tap down a few degrees come Sunday, as onshore flow increases. Lots of pink faces possible at work or school come next Monday the 13th, but oh the joy of outdoor warmth & sunshine.
Right now, we see the dry period continuing through the week of May 13 - 17. The onshore component will hold temps in the pleasant zone (not too hot, not too cold) all that week. There should be a notable west wind up the Columbia River Gorge - go windsurfers!
With some variation, models do project a return to showery, cool conditions around Sunday or Monday, May 19,20. However, that downturn may be short-lived, as high pressure is on the charts to rebuild an onshore push by Wed the 22nd, for a return to pleasant conditions.
A quote used in 2009: “Men fight for freedom and then start making laws to get rid of it."
-Rufus
3,125
What is your forecast for 11-12 for the RWR and 13-20 for a cruise. It looks like it will be sunny, but will we have wind?
Nov 6, 2006
10,087
Did a 4 day mini cruise with an old sailing buddy mid last month. It was good to be back around the gulf islands off the Mississippi coast. IMG_2021.jpeg
Prognosis is not good for the sailing race, Hayden. Light winds and plenty of sunshine appear to be the call for the day.
Good tactical planning and conderation for an anchor on Sat night to keep you from losing ground might be considered at or around Possession Point.
The Ebb Tide will be big with a -2ft predicted on the 11th at Port Townsend.
I sent you and email.
What is your forecast for... 13-20 for a cruise.
My crystal ball is at at the edge of her weather vision. The 13th through the 16th are looking to be very nice days to be on the water. You will be under the influence provided by a High pressure cell centered about 1000nm SW of the Juan DFuca on the 13th. The High cell is blocking a Low storm cell that is North and West of Vancouver Island in the Gulf of Alaska. Watch the clouds as you enjoy our cruise.
More info will be availble over the next several days.
Apr 5, 2009
3,125
We have been watching the weather and was worried about the loads of sun. The last couple o times my daughter and family came home to go on a cruise, it was in July, and we had lots of sun and no wind at all. This year we opted for May hoping to finally get to sail.
-Rufus
So true. They do that here in Live Free or Die, New Hampshire, all the time. City folk become enamored with the simple, free, rural life, so they buy a house up here. Then, they get involved with local politics and begin a push to turn their little patch of the perfect life into the one they ran away from. It's all because of fear. They are afraid if they don't restrict freedom, someone else will come and take it away from them.
-Will
Is that legal? :)
YES
No penatly for sitting still at anchor. Considered Good Seamanship to wait out a foul tide.
  • Start your motor = DQ.
  • run aground. Need a toe = DQ
  • Run out of time seekign the finish line = DNF
Better have enough rode...
Deep waters. 2-3 knots current reported in center of Possession Sound the route North.
Get caught in the middle where the waters are 100 Fathoms (600 Feet) and your heading to Seattle.
This is a fun race with a variety of tactical considerations.
Apr 5, 2009
3,125
Is that legal? :)
I have anchored in this race more times that I care to remember. The first time was south of the Possesion point bell bouy right about the 24-fathom line. only time I have anchord in 145' of water. I either dropped the hook then or I was going to get flushed all the way back to Pt Wilson before I saw another "anchorable depth".
Apr 5, 2009
3,125
YES
  • Run out of time seeking the finish line = DNF
In this race, starting your engine is not an automatic DSQ. Back in 2008 when I was the commodore of WINSA, I wrote into the rules that use of engine was allowable to clear your boat out of the way of shipping. avoiding imminent grounding or to render assistance. Here is section 12. of the sailing instructions. I thought it was prudent given that we were sailing in a major shipping lane, parallel to the VTS and in currents often exceeding 5-knts.
12. USE OF ENGINE Use of engine for thrust is prohibited while racing except:
(a) To help another vessel in distress.
(b) To avoid impeding commercial traffic.
(c) To avoid an imminent grounding.
If power is used, it must be reported to the Race Committee at the finish line. Also, a written report must be made on a protest form, showing the location, time, duration of power use, speed, direction of exit and that the competitive position of the yacht was not improved. If the last item cannot be demonstrated adequately, a time penalty may be imposed.
