Haven't posted in a while, but that doesn't mean I haven't been busy!! At the beginning of last season, I noticed that the depth transducer (located outboard of the STBD engine bed was leaking. Actually, it was the plywood backer that was rotted. The PO had tried to tighten it, but to no avail. Therefore, given that all of the instruments were original ca. 1985 Datamarine, I decided to put an N2K backbone in the boat and change the anemometer, STW log and depth transducer. I'll do another posting when it is completed, but for now, I'll concentrate on the relocation of the depth transducer.
I decided to locate the new one in the stem, where is should've been all along, IMHO. It is now on the starboard side, opposite the blackwater overboard discharge valve and just aft of the holding tank. As for the original 2" hole, I employed the classic WEST System method of filling it in. The hull laminate is .5" thick, which translates to a 6" diameter patch area. This is because there is no access next to the beds to do any grinding. I covered over the hole from the inside with a piece of green class and proceeded to remove the outside hull material to create the concave shape to be patched. About halfway through I found a void (see attached)!! Turns out that an athwartship stiffener was added when the hull was laid up and the underside is hollow. I have seen these before when visiting builders but did not realize that they could be hollow. I always thought they would be solid or cored. In any case, it was perfectly dry which means that the watertight integrity has never been compromised. At this point, I'm not sure what to fill it with. I'll make a few calls tomorrow and will also call WEST as their tech support is excellent.
