Before hurricane season I was thinking of dropping my h260 mast and storing it either in normal straight spot with that pvc mast at rear, or maybe DIAGONAL? My slip in water is only about 35 feet long so if can drop 5 feet from actual length I take up this would help.
At anchor I wonder how much would having mast down lessen the pull on rope of a strong wind. Wind climbs with height so as a I guess maybe 80%?? I've been at anchor in a bay and enjoyed seeing myself slide across the bay as my anchor is pulled by hi winds thru the mud even though this is supposed to be rare.
If have keel down on h260 and run into shall mud at NON STRAIGHT ANGLE as a guess this snaps the keel so gotta be sure to pull it up if heading sideways toward shore? HHMMM.. GEOMETRY suggests I guess if anchor is fighting the wind a bit, then at worse you BACK INTO THE MUD BANK by shore or sand by shore, so one's boat is usually pointed away from shore as you are pushed into the shore???? Due to this geometry maybe a couple poles at rear pointed down 4 feet would act as legs to stop boat keel from hitting. .. . Lesson is never risk anchor in high wind and pull up keel to be safe, haha.
I rarely sail, I motor far along midwest rivers or texas narrow ship channels inside the barrier islands. I wish Hunter made a MASTLESS SLOW BOAT with nice table and bathroom and some lead to help stability. Anyone want to trade my sailboat for a nearly wrecked h26 and $10k, haha?
BON CHANCE!
BON CHANCE!
