Just rewired my mast with new wire for anchor light and combo deck/steaming light. Testing connections with 12v battery prior to stepping the mast and all lights worked. Stepped mast and now anchor light and steaming light work fine (LED), however when I switch on deck light volt drops at least one volt and am/fm radio loses power. Radio is not wired to mast wiring at all. Of course the quick connect is in the mast. Quick connect was tested prior to stepping mast and all read proper voltage. Suggestions
