Thanks. at one point the engine would not start. The part with the white zip tie was loose so that it was shaking around rather than bolted to the engine. I managed to get it bolted again but now I'm worried about it thinking that maybe I should just replace it. Also the box with the white zip tie below the emergency switch is loose. Should I be concerned about that?
