1986 Catalina 27. I’m noticing at times a very slight exhaust smell in the cockpit when motoring. Engine compartment can look a little foggy too at times. I put in a CO detector in the engine compartment but it didn’t alarm. I noted trace brown dirty water at the mixing elbow. See photos. I have no idea when this was last replaced if ever.
Reading other posts it sounds like mixing elbows in the exhaust riser are high failure points given hot exhaust and saltwater and should be replaced every 5-8 years.
Also, what is the purpose of this tube coming from the top of the engine in second photo? I couldn’t find it in the typical diagrams. Is this the crank case ventilation or something else? I can feel a little puff of air coming from the end of the tube where it ends near the starboard side of the heat exchanger but it doesn’t feel hot or look steamy. There’s a touch of oil just inside the tube if I put my finger on the end but never any oil actually leaking or dripping out.
Questions:
1. Is a little put of air coming from this tube concerning?
2. Should I consider a compression test before changing the mixing elbow and exhaust riser?
Thanks in advance.
Questions:
Thanks in advance.
