found it on the boat and can't imagine what it is for:
i'll try that but I doubt it . the refrigerator seems like it's 3 feet deep but there might be some thing Im missing in there. thanksDivider panel for inside the fridge?
I don't get how it attaches yet but definitely will check that out. Thanks!That goes into the slots in the walk thru portion of the transom behind the wheel by the swim ladder. Leaves the bottom couple inches open so water can drain but a can of beer can't. Here's a picture I pulled off the web shows the slots on another model of Catalina.
checked it out and it is now very obvious how are attaches! thanks!I don't get how it attaches yet but definitely will check that out. Thanks!
I sometimes remove the seat if I'm going to stand at the wheel for a long time ... be sure you remove it when removing the seat, because it will be very easy to trip over it! That could be a nightmare!checked it out and it is now very obvious how are attaches! thanks!
you remove the seat so you have more room to stand? in my case I think the swim ladder would prevent me from falling off.I sometimes remove the seat if I'm going to stand at the wheel for a long time ... be sure you remove it when removing the seat, because it will be very easy to trip over it! That could be a nightmare!
It does, except when it is in the water! (I have been known to leave the slip with the ladder in the water!you remove the seat so you have more room to stand? in my case I think the swim ladder would prevent me from falling off.
i'll be on guard against that! thanks!It does, except when it is in the water! (I have been known to leave the slip with the ladder in the water!)
