Rudder Sensor
mjsb
Jan 28, 2021
57
Hunter 31 0 TSS, Apollo Beach FL
I am planning to install a Raymarine rudder sensor on a Hunter 31. Has anyone installed one before? I am looking at the 4 page installation diagrams and they don't quite make sense for my 31. If I installed the Rudder Sensor to the ceiling in the back of the quarter berth, it would seem to fit, work not sure. The fittings and clips on the rudder sensor would be upside down. Any help would be appreciated.
Check the installation manual, there should be a calibration procedure.
Nov 6, 2006
10,257
Here is what I did in my H-34; similar but not identical to the setup on the 31:
it is mounted inverted. I had to nibble a bit of rudder stop off to clear the pushrod.. Measure carefully. If I remember correctly, I had to reverse the red and green wires going to the control head.
Likes: SkookumZac
What does a rudder sensor do? This is to know at what angle the rudder is?
-Will
Nov 6, 2006
10,257
It tells the autopilot how much the rudder is moving and where it is. a secondary display is on the autopilot screen when the pilot is in "standby" It can be used to get sails balanced before the autopilot is engaged so the pilot does not have to work as hard.
If I remember correctly the calibration procedure starts with centering the rudder and telling the AP that the rudder is centered. It then goes through a series of S turns to learn the rudder's range. Don't do this on a narrow waterway or in a lot of boat traffic.
JamesG161
Feb 14, 2014
8,111
Hunter 430 Waveland, MS
My Rudder sensor must be set in Dealer Mode and done in a harbor. Its limit is then set ± 24 deg angle.
You normally have a Rudder Stops in your Quadrant area the prevents your rudder movement.
Why?
Your Rudder, when Backing up, would be damaged, if allowed Swing more than ± 24 degrees.
Jim...
mjsb
Jan 28, 2021
57
Thank you, this is what I was thinking. Thank you for the quick simple response.
Jan 7, 2011
6,018
Oday 322 East Chicago, IN
You can install it upside down if that is the best way to mount it. You may need to switch the wires to the AP around…so it displays properly.
Dec 25, 2000
6,071
Our 1991 boat came with an Autohelm 7000 course computer, 6000 control head and rudder sensor. Always impressive how the boat tracks a course especially with some drift.
