Am I the only one here who doesn't know what a penboard is?Does anyone have the measurements of the penboards for a 1983 O'Day 30?
No.Am I the only one here who doesn't know what a penboard is?
You’ve got it. At least that’s how I’ve heard the term used.Seriously, my guess its the boards to close the companion way. Just a guess.
I've also heard them called washboards or simply companionway boards. Learn something new everyday.As I'm close to Philadelphia my guess it's what they used to wrap the scaffolding around the statue of William Penn when they restored it way back when.
Found this on the forum, asked about previously. Go to the search and enter this title
Companionway replacing pen boards for easy access while cruising
FolksAm I the only one here who doesn't know what a penboard is?
Thank you for the clarification.Folks
I apologize that my use of the term penboard/pen board has caused so much confusion. I've been using that term for 42 years and have never met someone that indicated they were not familiar with it. The item I was referring to are the plastic or wood panels that close off the main hatchway to the cabin of the boat. I've found that they are also referred to as companionway panels. I would attach a picture of my pen boards but my boat is sitting in the icecold water 40 miles away. In the meantime, I have attached a picture of the pen boards on a boat I found on the internet.
Or drop boards.I've also heard them called washboards or simply companionway boards. Learn something new everyday.
That's easy, they are just big enough to slide in easily and seal the hatch. The joint between the boards is not at right angles to the board, it is either sloped or keyed so water can not get through the joint. Close enough?Now if we only knew the right size for them.![]()
Where would the fun in that be?Can't you keep it simple and just call them hatch boards?
