I bought a sailboat with a retractable bow sprit for using a genaker. Unfortunately I am not 100% sure how its used. The bow sprit appears to click into a couple of pad eyes on the deck for retracted or extended which seems obvious enough. The part I am not sure about is the length of line running through inside the length of it. The line is quite long. Again its pretty obvious that the tack of the genaker, or a furling rig would attach to the forward end of this line, but what about the other end? Would I attach the other end to another line run back to the cockpit and locked in a brake or winch? Is this meant to be adjustable? Adjustable for maybe different sizes of sail? Or adjustable for different shapes of the sail? The sprit is similar to the attached photo but the line seems at least 1-2 meters longer that the sprit. Any help is appreciated.
