Watch this excellent presentation by a seasoned world cruiser:
Not so. The direction and speed of the current won't cause the electric power to be used up any faster, relative to diesel. Speed through the water will remain the same in either case and the same relative progress will be made for the same relative consumption of energy.Will, the difference is that with electric, you will use up your limited power reserves
much quicker than with an reasonable supply of diesel.
I think that the point is you have SO such limited range on an electric system, that the counter-current becomes an issue…we wouldn’t give it a second thought on a diesel engine-powered boat…but it HAS to be taken into consideration on an electric-powered boat.That's not to say there isn't more range in a diesel design than in electric, just that, if electric can only get a tenth of the range going with the current, it will still only get a tenth of the range against the current. .
-Will
He stated his current panels produce 2.5kWh per panel on a good day, and if he increased to 9 panels he could theoretically generate 22kWh in a day. He isn’t saying that 22kWh will get him 66nm, but that with 5-10 days of charging he could generate enough to fully charge the three 30.4kWh batteries in the recommended Oceanvolt setup… and that is enough for 66nm. He is probably accounting for other house loads and days with lower production to get the 5-10 day estimate.He claims he can only go 66 nm on a full 22 kwh charge. I really have no idea how he is coming up with that number.
I'm not sure what Thomas's point was in making this video. He is obviously upset about having invested a lot of money into electric propulsion and is very disappointed with its performance.
After my earlier post, YouTube stepped in suggested I might have been a little rough and started feeding me more Sailing with Thomas videos. About an hour later I learned he does indeed have a Yanmar and caries a lot of extra diesel in his dinghy. It was not clear in the video linked above that he did have a diesel.He stated his current panels produce 2.5kWh per panel on a good day, and if he increased to 9 panels he could theoretically generate 22kWh in a day. He isn’t saying that 22kWh will get him 66nm, but that with 5-10 days of charging he could generate enough to fully charge the three 30.4kWh batteries in the recommended Oceanvolt setup… and that is enough for 66nm. He is probably accounting for other house loads and days with lower production to get the 5-10 day estimate.
Also, his boat does not have electric propulsion, it has a Yanmar with fuel for 1000nm range. That was the point of the video… Range=Safety. The money he spent was on the solar installation, and that is what isn’t performing as well as in the Med or Caribbean.
What I am asking of those selling products and ideas is to quit treating us like fools, be honest, objective, and give us the best accurate information available. We can come to our own conclusions.
I agree with your opinion on his presentation. This is the only video of his I have seen, and I did have to pause and rewatch some segments to figure out what he was trying to say. But I do also agree that you should be able to move the boat 500nm or so, not just for tropical systems, but also avoiding the worst parts of fronts that could ruin your day.A good part of my adverse reaction to his presentation is to the manner of his presentation. He doesn't provide clear and easily understand data and he doesn't allow for the viewer to come their own conclusion and opinion. His conclusion is the right one. Well, Dan and Kika on Uma, might argue otherwise. They have spent 10 years cruising in the Caribbean, Northern Europe, the Med, and above the Arctic Circle on boat powered by OceanVolt (at least for the past few years, prior to that they had DIY motor).
Is that even a good argument for a sailboat?As for out running hurricanes, don't sail off shore in hurricane/cyclone season, seems simple enough. Yet, Thomas seems to have a propensity for sailing in and near hurricanes.
