Discouraging article on older Jenneau Sun Odyssey fixed port replacements
The podcast lady K sailing made a comment about this exact same thing when he was comparing several different boat models and their pluses and minuses
Likes: tfox2069
Apr 8, 2011
774
Hunter 40 Deale, MD
I saw that podcast, and the article I posted here is the first thing in print that I've seen that further amplifies the problem. If I owned a Jenneau with those artistically shaped windows I'd be really worried about resale based on Lady K Sailing and these developments.
:plus:
Or it’s an opportunity for some entrepreneur:beer:
Likes: tfox2069
Any boat with a large curved port light is subject to this issue. If the acrylic is not properly heat set, eventually the acrylic will pull away from the hull. In the distant past Bowman made a hatch with a curved surface and those hatches had this issue (I had one). The larger the port and the greater or more complex the curve the more difficult it will be to replace and repair.
Likes: tfox2069
Sep 24, 2018
4,642
Catalina 30 MKIII Chicago
Am I correct in assuming that the window is made of thin material, otherwise, it wouldn't break apart upon removal?
Apr 8, 2011
774
Hunter 40 Deale, MD
Not necessarily. They can also become crazed and brittle from long exposure to the sun such that when the seal holding them in place is being cut the stresses - or stress relief - can fracture the brittle window material. It's one reason why having them removed to either be rebedded (if not too damaged) or used to make a duplicate can be expensive in terms of labor because of the extreme care that has to be taken to remove them intact.
