Anyone played with Water Maker - Horizon /Sea Recovery Aqua Mini 170 (7g/h or 26L/h )
Has anyone done any modifications or upgrades.
These units are small by today's standards, but I have had mine some 15 years and its done 1200 hours. In 15 years it has never given me any trouble, haven’t even replaced the membrane, only pre filters, though I'm careful where I run it. It’s a 12v DC unit and has auto rinse cycle which I believe is what has saved the membrane, along with only running it in clean water. It has a small 26” membrane, now due for replacement. So Im contemplating replacing the existing membrane with a 42” version.. I have a low estimate of this being successful, but someone has suggested the existing high-pressure pump (see attached) has sufficient flow to keep up the 850PSI and if that’s true it should work. But if not then the plan is to replace the high-pressure pump with a typical 230v Hydroblaster (water blaster) The idea being to keep all the rest of the plumbing, electronic smarts, gauges and cosmetic integration.
So has anyone played around with Horizon water maker, any first-hand experience, any conformation the attached pump can keep up, along anything along any of these lines?
