that's great! Do I have an ignition position that is on without an alarm going off? And can I use the blower independent of the motor? Thanks
Most likely, your blower is powered off the ignition switch and the alarm will sound (unless it is broken like my alarm was until I replaced it). If you want to run the blower without the ignition "on" you can probably wire it to a direct power source inside that panel.
That 8" x 8" vent in the galley bulkhead may be for a reverse cycle air condition system as mine is. If you don't have reverse cycle, then you should be able to use it as a vent since it opens directly into the port lazerette. Pulling air from the galley is a good idea anyway!
But now that I think about it, I don't think there are any vents in the stern. In fact I don't think the engine blower vents outside either. I think the ducts just discharge into the rear locker .... Hmmm, now I'm wondering .... I don't use the blower very often as it is and I really haven't thought about it before! I've been back there enough for wiring and cables, but I've never thought much about ventilation from the blower!
If your head smells, I'd bet $100 that you have stink from your hoses. That's the first thing I replaced on my boat. I threw out the toilet as well. On 2 boats that I've owned, the toilet smelled even worse than the hoses ... and both "looked" as clean as brand new. You wouldn't think that porcelain could smell that bad, and maybe it was all the internal guts that smelled, but removed from the boat and the hoses, it was evident that the toilet is not immune and no amount of cleaning made a difference. On my Catalina, I put in an electric, freshwater toilet anyway. That turned out to be a project, though, as the pedestal on the 320 is inadequate.
The PO on my boat put a holding tank vent filter in the closet just aft of the head. What a bad idea that was! All it did was lengthen the vent hose and put the stink in the closet! I got rid of that right away, but the closet is still infected with odor - I'm going to try more cleaning and possibly ozone to take care of it!
