Hello All-
I have what feels like a silly question. I have a Yanmar 3HM35F that starts right up every time. Occasional puff of smoke on start up, but otherwise seems to run fantastic with no issues that I can tell. I have been running it at roughly 2200 RPM as that pushes me along at close to 6 knots on calm days with around .75g/hr consumption. All seems good.
Well, reading the manual I see my continuous rating is 3200 RPM and my 1 hr is 3400. I read that running at lower RPMs can be detrimental so I have been attempting to run at higher RPMs. Occasionally I am able to get the RPMs up to roughly 27-2800 RPMs, but what I find is that my throttle tends to slip back down to the 2200 range when I let go of the throttle control. In other words it runs fine at my desired RPM, it just slips back down to the lower RPM with out physically holding the throttle in place.
Is this some mechanism in the engine to prevent over reving when not up to temp? Or is this simply that my throttle cable is not holding the desired location? I do find that if I hold the throttle in place at my desired RPMs for a few seconds that the chances of it staying in place are better than if I rev up and let go.
FWIW my throttle/shift levers are very basic. They are both basically flat stock mounted vertically on the sides of my pedestal. Pull up on the shifter to go into reverse, push down to go forwards. Throttle is pull up to increase revs and push down to return to idle.
