Convert Idiot Light to Thermostat Gauge?
Oct 19, 2006
337
Hunter 27-3 Brownsville, VT/Mystic, CT
On my ‘07 Hunter 27 with a Yanmar 2YM15, I don’t have a thermostat, just an idiot light on the instrument panel. My exhaust manifold/heat exchanger just broke due to extreme corrosion (a sad tale not worth telling here, but I will share I was shocked by how clogged the piece was), and I have the replacement kit on the way from HDI Marine in Vancouver, Washington. That’s all good.
However, it got me thinking it would be a good idea to have an actual temperature gauge, not just an overheating warning light. I’m not eager to run a new wire from the instrument panel to the engine compartment. Does anyone know if I can take the wiring going to the warning light and switch it over to a gauge?
Thanks for any advice.
Mar 6, 2008
1,417
Yes you can as long as you have a grounding point on the instrument panel.
Jan 4, 2006
7,444
Not a good idea, in fact a terrible idea. If you go over temp. for any reason (a failed raw water pump perhaps) you want a screaming hi temp. alarm to draw your attention to the problem. With only a gauge, you may not notice an overheating problem for hours. Come to think of it, a seized engine would notify you quite promptly if you are overheating :yikes:.
This is really not as bad as you might think. I managed to go down through the bottom of the binnacle with a waterproof cable gland to ensure no water got through to the ceiling liner below.
From there just followed through to a good sensing point. None on the engine so I used one of the engine coolant hoses to the hot water tank. Because it's in a non conducting hose, you have to make up the ground.
Breaking this query down to simplest terms.
  1. Wire - yes the wire can be used for a temp switch signal (what you have now) or a temp gauge signal (what you desire)
  2. Gauge, the instrument that displays the temperature, you will need to acquire and install this on your panel. They have certain requirements as to signal they receive from the sensor installed on your engine
  3. Sensor, you will need to acquire and install a temp sensor on the engine or in a hose that contains the coolant from the engine (as Ralph indicates). On engine sensors provide more accurate indication of the engine temperature.
I totaly understand that point... but I lost a car back in the early 90's .... the idiot light came on about 2 seconds before the engine siezed. ... Now I only buy cars that have a functioning gauge.
Maybe the best solution would be to have both a gauge and a warning buzzer. Or a gauge with a buzzer.:shhh:
That way you can see that things are "not normal" before they become a crisis.
Jun 11, 2004
1,862
Oday 31 Redondo Beach
Yes. A gauge and a buzzer both.
My gauge and warning light are in an awkward place to see so I added a buzzer to the idiot light circuit.
Adds a lot of peace of mind.
Likes: rgranger
Jan 4, 2006
7,444
I completely agree BUT given a choice of only one which most people with boats have (audible alarm only) I'd take the alarm. And that's why I have both.
Likes: rgranger
Jun 11, 2004
1,862
Agreed.
He already has a light so it should be quite easy to add an alarm on the same circuit.
The gauge would be nice but a little more involved installation.
Oct 19, 2006
337
Thanks for all the input so far. Very helpful!
As far as "swapping" the idiot light for a gauge creating a potential it's-too-late scenario, truth is the panel on our boat is not at the helm but on the starboard coaming and is blocked from view most of the time. Even if someone isn't sitting in the way, it's not easy to see what's happening there. So if the light triggered, I'm not sure would notice it anyway, or at least not immediately since I'm not normally focussed on that area.
With all the food for thought you've provided, you got me thinking that if I do indeed use the wiring to the warning light to put a gauge on the instrument panel, I should install an idiot light on the binnacle next to my chart plotter, which is an area I do look at regularly. The cable path from there to the engine compartment is much easier than from the starboard coaming.
Likes: rgranger
Jan 4, 2006
7,444
Rather than just a light which shows what system is the problem, I have an alarm which is so loud and ungodly, you can't ignore it. Everything alarm switch on the engine is wired through the one audible alarm and then a glance around the cockpit will show the one light that's on which shows who is causing all the ruckus.
Mar 6, 2008
1,417
VT, if an audible alarm will help you, just install a 110 dB 12vdc soanalert across the idiot light and mount it inside the instrument panel. I guarantee you that you will hear it.
Likes: Richard19068
Blitz
Jul 10, 2007
716
Seidelmann 34 Atlantic Highlands, NJ
years ago I thought someone made a gauge that would alarm when it reached a set temperature. Not sure where though... not much help I know
